When you do the move here the robot is solving for the tcp location, not joint angles. They all have the same tcp position as there are two solutions for how to get to that pose. My understanding is that basically the robot is choosing the easiest path to get there, depending on where you are starting from it can get there by two paths and so will have two different joint solutions. That’s what you are seeing. It’s the same issue I have seen before with movel in programs where you have a need to put a movej waypoint before the movel to ensure you are actually in the correct joint orientation prior to executing the linear move.
Hello pros,
after teaching a feature plane on the UR (first image), when i try to "move here" the arm moves to the Origo but rotated by 180° in either wrist 0 (second Image) or wrist 2 (third Image), depending on where it starts from. What could be the reason behind this and is there a way to avoid this?
Also since updating the UR from SW 3.5.4 to SW 3.7 I'm not able to select the axis of the feature plane created after the Update (I can't pop up the feature plane). Is anyone else having this problem?
Kind regards
