I'm trying to apply force to a part before closing my grippers. I can do this successfully on individual picks but I'm having trouble making it work inside of a pattern. The first part always works correctly but on every subsequent part it wants to move towards the pick point of the first part. On a side note, the program works great if I disable the force command.I'm new to this so any help would be appreciated.Thanks in advance.
Hi @a_machinist,Could you share some more information about your application? What robot are you using?Could you share your current program? What kind of pattern are you using?
@Nicholas_Francoeur Yes, sorry. It's a UR10e and I'm using a square pattern.I've attached the program.
Hi @a_machinist,Use a thread to monitor the force sensed by the FT sensor using the get_tcp_force() function and then use the Fz value obtained instead of the Force mode you're currently using.See below and attached: Robot Program zero_ftsensor() If ForceXYZ[2]≤5 MoveL Waypoint_2 MoveL Waypoint_1 Thread_1 ForceXYZ≔get_tcp_force() sync()Make sure to use the zero_ftsensor() right before you need to read the Fz value from the sensor.The movel used should be relative.
Thanks in advance.
