We use a variety of methods from hard automation where parts are being presented to the robot automatically in the correct orientation to vision guided vibratory tables. We have one system where the humans load a large stack of parts and then a pneumatic gantry robot picks up a part and places it in a nest that the UR uses to assemble and pick up the part for the next operation. We have several vibratory feeders where we use vision to locate and pick the part. Some of these are multiple robot setups where one robot is picking random parts off the table and then orienting them for a second robot that uses vision to locate a feature on the part to place it in the assembly. We have two robots for cycle time, sub 4 second part to part pick times
Part presentation is definitely one of the biggest challenges we face on a day to day basis. The issue is finding a reliable way to locate parts that meets the requirements of the robot while not overburdening the operator. We have some cells where the operator loads a part or a few parts and cycles the robot. The robot is then able to process the work while the operator loads a part into another fixture or another robot. This is good for quick deployments as well as lower volume jobs where it’s hard to justify spending upwards of $25k on a feed system.
The most persistent and hindering problem i have with any of my automation tasks is presentation. I was wondering how everyone else out there solves this problem. The fact of getting part reliably in the same spot and in the same orientation. One of the only thing hindering me from tripping the amount of work load that is done by the robots. So, I just wondered if you guys had any suggestions, or just this that help with this issue.
