@matthewd92
I did this test here and I got the same result. I noticed that if I don't power it on right away and use the Exit button, the program and the installation file are still there with the modification I did. But we must be aware of it and thanks for this notice.
louis_bergeron
Enric
In version 3.6.1 and 3.6.0 we will be working on testing simple pieces of code and so we will create a new program with just a couple of lines of code. We store our work in progress programs in a folder and so when we create these small programs if we just hit play before saving them the system switches from the currently loaded installation to the root level default installation file. It used to ask if you wanted to load the current programs installation or use the currently loaded one at which point I’d just choose to run the currently loaded one and change the program to match. Once we saved the program into the current working folder then it would stop asking about switching installation files.
What happens now is it switches to the root level default installation and turns the controller off. This causes issues obviously and not the least of which is potential lost work if you have made changes to the installation file and have not saved it prior to hitting play.
Anyone else experienced this? We have seen it on every robot running 3.6.0 and 3.6.1
