Hi @TheoSaify
Did you used a moveL and set the snapshot variable used in the cam locate as the feature?
can you show me how ?
Hi @TheoSaify
i taught the robot to detect an object, and i saved the movement toward the object.
When i try the program the robot won't make the registered movement. He started moving in wrong directions after i change the position of the object from the teached position
