You can do that, just need to define the areas in if statemtents and then query the current position of the robot to determine where it is. Within the if statements you would define the path back to home from that zone. Anytime the robot is started that hiking routine would run.
Thanks for your responses !!
I would like to know if it’s possible to define areas, and then if the robot is stopped in one of the area to recover back to home position if a reset button is pressed.
