First let me know the gripper you will use 2 finger or 3 finger?
Catherine_Bernier
Robotiq_Customer
I'll be using the 3F gripper with EthernetIP communication protocol.
Catherine_Bernier
Ok perfect.
Wiring setup
First you will have to connect the power supply cable to a 24VDC 2A power supply. Here is the pinout for the gripper.
Then, you will have to connect the Ethernet cable to your robot's Ethernet port for the EthernetIP communication setup.
Communication Setup
You will then be able to set the correct device/communication parameter for EthernetIP in your robot. You will find the communication parameters for EthernetIP HERE.
You can also use the EDS file that can be downloaded here.
This will establish communication between the robot and the gripper.
I/Os setup
You will then have to map the EthernetIP IO's in your robot. By changing these IO's you will be able to control the gripper. You can look at the Control section in the manual to help you map out the correct IOs on your robot.
Let me know if you need any other information!
David_Levasseur
I would like to know how to integrate the gripper and a Fanuc robot.
What about the setup and communication?
Thanks.
