I was thinking something like this but I am not sure (I am unable to test it right now).
You’re welcome
You’re welcome
Hello all,
I am trying to program a timer on a UR10. Since our cycle uses two robots, I would like to program the timer only in the second robot (close to the end of the cycle) to the same point one cycle later, as the program will be running in a continuous loop.
I have already set a cycle counter by using the following code:
In the BeforeStart, I have the following:
count=0
addcount:=False
In the robot program I've got:
addcount:=False
addcount:=True
Wait=0.01
addcount:=False
And then I created a thread with the following code:
If addcount:=True
count:=count+1
Wait=0.01
For now it seems to be working correctly. Is there any way I could use something similar for a timer? Maybe instead of time:=time+1 it would be something like 0.01 or 0.008?
Thanks!
