You are able to do this by keeping your moves relative to a feature. movej should only be used for moves in free space where collision is unlikely. you could also fixture the robot base in a way that could be more repeatable using something like ball locks or pins.
I want to be able to move my whole robot from setup 1, put it to work on another machine (setup2) , and then put it back at the machine of setup 1, calibrate the robot with 1 or 2 waypoints, and run the whole setup 1 program again without having to change it. Is this possible in any way? Because the company would like to be able to move the robot between machines. I figured I could try to do this by setting feature planes, but only movements L and P are supported with features and are much slower than movement J type. Thanks in advance.
Emile Derache
Student @ KU Leuven
Graduation project with Niko (Belgium)
