This is actually a bug in the camera. The LED is supposed to turn off but does not until the program loops through a second time. Robotiq has released new firmware, which addresses the bug. It is a beta, however. You will need to submit a support ticket to receive the beta firmware if you are OK with being a beta tester.
David_Levasseur
Thank you @Enric, I added you to the list. We plan on releasing the beta version this week.
Enric
After Camera locate in the Robot program section the LED of the Camera stays on while moving . Is there a way to turn it off or even to reduce the brightness ??
