Does the Omron PLC have Ethernet IP? If so, that’s an option, I believe you can find the EPS file on the UR website and that would give you access to the IO on the PLC.
If if all you want is expansion IO using modbus why not just use a modbus module. We use the TBEN series from Turck for IO expansion as it’s really easy to use and is already configured to use extension cables and so we screw the cable directly into it. The module we use has 8 port which gives you up to 16 configurable points as either inputs or outputs. It’s very easy to setup, you set the IP address on the face of the unit, plug it in and then simply go to the modbus screen, add a client and point it to the IP address you just set. You can use discrete inputs or outputs and they are referenced starting at 0.
Hi all,
Corrently im working on a project with a ur5 dats needs mores i/o slots that what it got. So i plan to use modbus option to add a new plc. I have a modular OMRON plc with the CJ2H cpu65-eip (http://www.ia.omron.com/products/family/1993/specification.html ) and im would like to know if its possivel to directly connect the omron plc to ur5 robot via ethernet port on both equipments and how to proprely setup the modbus comunication between them since i cant find nothing relating OMRON and UR slave/master plc configs.
