@urosTPV yes, as long as you have your connection to the Edge Gateway that connects to the internet. You will probably use a switch, robot is connected to the switch, which links your actual network on one side and the connection to the edge and the internet on the other side.
Can we use the insight application if we already have the IP address used for the modbus?
