Hey there.
Are you using the Robotiq tested adapter?
If not, this might be the problem as the pinout might not be correct.
Make sure to refer to this image:
The simplest way to proceed would be to contact our application engineer and get the Robotiq tested adapter for this application.
For more info on the wiring, you can get access to the support manual here.
I want to communicate in Modbus RTU with the Robotiq FT300, but I can't.
I am using a RS232 to RS485 adapter as I know your sensor communicates in RS485.
Any ideas why it doesn't work?
Thanks
