Hi,I installed the URCap. I can activate, open and close the gripper (2 finger 85) on the toolbar. But when I put "rq_reset()" in a UR teach pendant program and try to run the script, it is stuck there forever (showing a blue arrow to of left of rq_reset()) and never go to the next line. What could be wrong?Thanks.
Hi David and other experts,Thanks for the quick response. I very much appreciate it. I tried, but doesn't seem to solve the problem.I attached my simple script below. The gripper opens and closes 10 times as it should be during the Loop. But once outside the Loop, it passes rq_init_connection(), then again struck in rq_reset(), never goes to rq_activate_and_wait(). Any other idea?BTW, where can I locate that rq_reset() script? Never been able to find it anywhere...Thanks.
Ah, so seems I need to do rq_reset(2). Seems like if I don't have the number inside, the default is 1, my gripper is at 2. now it is solved.
Thanks.
