This is an example of Pick-and-Place program provided by Denso.This is for a Robotiq gripper 85 or 140 and Denso RC8 controller.'!TITLE "PickNPlace" #Include "Robotiq.pcs" #Define Home 0 #Define Pick 1 #Define Place 2 'Register Defines #Define FaultStatus &b00001111 #Define IniStatus &b000000001 #Define MotionStatus &b00110000 'Gripper Close/Open Values #Define Close &hFF #Define Open &h00 'Gripper Force Values #Define MaxForce &hFF #Define PickForce &h0F #Define PlaceForce &hFF 'Gripper Speed Value #Define MaxSpeed &hFF #Define PickSpeed &hFF #Define PlaceSpeed &hFF 'Gripper Object Detection Values #Define FingersAtPos &b11000000 #Define ObjectDetected &b10000000 Dim Opt(5) As Integer 'Option Array (Necessary for Robotiq Function) Sub Main TakeArm 'Takearm Semaphore Dim error_flag As Integer 'Error Flag. Move P, @0 P[Home] 'Move to Start Position error_flag = GripIni 'Connect to Robotiq If error_flag <> -1 Then 'Exit Program if fault detected. PrintMsg "Fault Encountered!" Call Robotiq("Disconnect", Opt) Exit Sub End If 'Pick Part Section-------------------------------- 'Move to Pick Area with Next Statement Approach P, P[Pick], @P 70, Next OpenGripper 'Open Gripper while moving to Pick Area Approach Move L, @E P[Pick] 'Move to Pick Part PickPart 'Pick Part Depart L, @P 70 'Depart from Pick Area 'Place Part Section-------------------------------- Approach P, P[Place], @P 70 'Move to Place Area Move L, @E P[Place] 'Move to Place Pace PlacePart 'Release Part Depart L, @P 70 'Depart from Place Area End Sub 'End of main program Function GripIni() As Integer GripIni = -1 'Initialize Return Variable Call Robotiq("Connect", opt) 'Connect Gripper Do While(1) Call Robotiq("GripperStatus", opt) 'Get Gripper Status 'Check if there are any Faults If(opt(2) AND FaultStatus) > 1 Then GripIni = opt(2) 'Send Fault Status. Exit Do End If 'Check that Gripper Has been set for activation gACT == 0x1 If (opt(0) AND IniStatus) = 1 Then 'Check That Activation Has been completed gSTA != 0x03 If (opt(0) AND MotionStatus) <> 1 Then Exit Do 'Exit Loop End If End If Loop End Function Function OpenGripper() As Integer 'Initialize Return Value OpenGripper = -1 'Set Gripper Options Opt(0) = Open 'Open Position Opt(1) = MaxSpeed 'Full Speed Opt(2) = MaxForce 'Max Force Call Robotiq("Move", opt) 'Move Gripper 'Wait Until Gripper is Open Do While(1) Call Robotiq("GripperStatus", opt) 'Get Gripper Status If (opt(0) AND FingersAtPos) Then OpenGripper = 1 Exit Do End If Loop End Function Function PickPart() As Integer 'Initialize Return Value PickPart = -1 'Set Gripper Options Opt(0) = Close 'Close Gripper Opt(1) = PickSpeed 'See Define Value @ Top Code Opt(2) = PickForce 'See Define Value @ Top Code Call Robotiq("Move", opt) 'Move Gripper 'Wait Until Gripper is Open Do While(1) Call Robotiq("gGTO", opt) 'Get Gripper Status If (Opt(0) = &b1) Then 'Gripper Stopped Call Robotiq("gOBJ", Opt) If (Opt(0) = &b11) Then PrintMsg "Fingers at Requested Position" Exit Do End If If (Opt(0) = &b10) Then PrintMsg "Object Picked" Exit Do End If End If Loop End Function Function PlacePart() As Integer 'Initialize Return Value PlacePart = -1 'Set Gripper Options Opt(0) = Open 'Close Gripper Opt(1) = PlaceSpeed 'See Define Value @ Top Code Opt(2) = PlaceForce 'See Define Value @ Top Code Call Robotiq("Move", opt) 'Move Gripper 'Wait Until Gripper is Open Do While(1) Call Robotiq("GripperStatus", opt) 'Get Gripper Status If (opt(0) AND FingersAtPos) Then PrintMsg "Object Placed" Exit Do End If Loop End FunctionFor the list of the command available, check out this discussion.You are welcome!
For the list of the command available, check out this discussion.This is for a Robotiq gripper 85 or 140 and Denso RC8 controller.
You are welcome!
