Hi @giannis_let,
Based on the polyscope interface
Joint acceleration is limited to 2292°/s but I can't find it for each individual joint.
Tool acceleration is limited to 150 000mm/s
But i know it is not recommended to use these value, @JacobBom could you please share with us the maximum recommended acceleration?
David_Gariepy
JacobBom
In the manual of the UR10 robot, it mentions the max value for the velocity (linear or for each joint). However, I could not find the range of acceleration for each joint (max values), or for the TCP. Could you help me?
Thank you,
Giannis Let
