Hello @giannis_let, If your robot has an Internet connection, we have a monitoring solution that might help. If you install Insights, you can monitor your robot from a web interface. With the advanced plan, you can even create your own KPIs, set SMS alerts, view daily reports and export event logs. You can read all about Insights right here and in the instruction manual.
David_Levasseur
I would like to connect a simulation program with the controller of the actual robot (UR10), in order to have a more accurate cycle time estimation for a robot task. I consider using Delmia, as it provides a tool for RRS connection, but I am not sure it could be done with a UR10 robot. Is there an easier way (or simulation program) in order to get accurate cycle time?
