HI,
just copied
from the UR-Script Manual:
ceil(f )
Returns the smallest integer value that is not less
than f
Rounds floating point number to the smallest integer
no greater than f.
Parameters
f: floating point value
Return Value
rounded integer
floor(f )
Returns largest integer not greater than f
largest integer no greater than f.
Parameters
Return
Value
rounded integer
Hello comunity,
I made this procedure to read the X position in meters.
Variable3 = get_actual_tcp_pose()
Variable4 = Variable3[0]*1000 %to get an integer part%
After that I want to sent this value to a register and I am writing set_modbus_register(adress,Variable4) but variable4 is not an integer. How can I make it into an integer?
thank you in advance
