Home › Applications
Etienne_Samson
Posts: 418Beta Tester Beetle, Wrist Camera URCap 1.3.0, Vacuum Beta tester Handy
Screwing application with UR |
2.3K views
/ Most recent by vidzz
in Applications
23 comments |
We have a customer looking to screw with a UR.
Is there any screwing gun that can be easily interfaced with the robot?
Electric screwdriver vs infinite rotation of the last joint, what to do and what not to do?
+1 418-380-2788 ext. 207
Ryan_Weaver Posts: 48 Handy
Certainly @Samuel_Bouchard -
While using the infinite rotation on the UR3 Wrist 3 sounds appealing, it isn't very practical as a screwdriver. The torque resolution is very coarse and speed can be slow.
We decided to work with Kolver because they are a local company who offers a variety of screwdrivers, feeders and torque controllers at a very competitive price when compared to alternatives we had looked at. The speed/torque clutch out routines are stored in the controller, then called via I/O from the robot. That means you can handle multiple different screws without changing out tools as long as the bit is compatible. The pluto screwdriver is small, lightweight and was easy to design an interface plate for.
The actual application programming was pretty simple - standard UR force control takes care of the "screwing" action very well. The most challenging part was getting the screw feeder to present the screws in a repeatable position. The version we have in the video isn't truly a "robotic" feeder, it's meant for manual feeding by a person. In order for the screws to vibrate down the track, it has to be free standing, which means it can vibrate around on the table. The video gets the concept across, but in reality, we would probably use a feeder specialized for robots.Ryan Weaver | Automation Engineer | Axis New England
https://twitter.com/axis_newengland -
gerenga Posts: 14 Apprentice
Samuel_Bouchard said:
Simple approach here is to show a first step low budget automation with UR.
Many of our customers already use a screw feeder and a auto screw driver so we wanted to show how easy it is to make the first automation step. Take a UR3, attached your available system, put your part in a jig where it usually is anyways and go.
In this case the customer has to invest only in the robot which makes the decision often easier. However beside it being a "quick & dirty" solution it has a few nice side effects.
Often the screw drivers are calibrated and there are fixed routing plans for the production procedure. We do not violate any of these so a lot of resistance for implementation doesn't happen in the first place as all the "nasty" documentation updates are not required to get going. Sometimes we have to make it as simple as that.
To market this further we just set up the application for the exhibition as people can relate to this process. However to not having to support this station in any way we decided that we want it running fully independent but screws in and out doesn't really show the repetitive action we wanted to show. So we decided to use a Zimmer group electric gripper and put the threads into the gripper fingers to show the Zimmer gripper precision as well. You may see some marks at the gripper finger threads but the counter was about 10,000 pieces when the video was done.
We have similar experience like Ryan regarding the manual screw feeder so we just locked it in place via aluminum profile still allowing vertical vibrations which fixed this issue.
We then had the topic that we wanted to show process control and a certain self diagnosis regarding our stations so we added a fiber optic sensor which confirms whether we actually picked up a screw because there is no interface between the screw feeder and the robot. However to make it a bit more obvious and fancy we relocated the sensor away from the pick up position to the side just for the show. In case the fiber optic sensor doesn't find a screw the robot will run another pick up cycle. Then we simply fasten the screw and beside checking the robot position when finished fastening, however to confirm that we don't actually still have a screw mounted on the tool when we go for another pick up run, we go to the sensor again and trigger a popup in case of detection to show self diagnosis functionality.
We are using the force mode as well as it is just that simple.
Once all screws are set, which is handled by variables in the robot program, the gripper opens and the screws fall back into the screw feeder. This is simply to keep the system running without the need to load or unload any material on the exhibition.
It's simple but effective.
Best regards,
Enrico
In this application we have 2 pneumatic drills, a soldering station and a silicone dispensing syringe (orange tool gripper). All of these tools are driven over simple I/O with the robot. The Loctite dispenser actually has a robot I/O port which made it easy and actually gives feedback that the unit is running. You can do manual operation or timed dispense, we use it in manual mode as it's just easier for what we are doing.
The torque/speed profiles are saved in the screw controller in 8 different programs. We call them via IO, but there may be a way to change them over TCP. I would recommend you give them a call, they've been very accommodating with us.
The second video is indeed a Kolver as @matthewd92 mentioned. I did not personally work with that unit. One of my coworkers was using it. His initial thoughts were very positive though. You can control speed, direction, and torque and have up to 8 different programs. He also said it is very quiet. I don't think he is a member here, so I'll see if I can get more information from him.
Edit: Found out he is already a user. @acmonteith Andy can you provide any info on the driver you were looking at?
@Ryan_Weaver is the communication using the kolver model in the new axis england application(EDU 2AE/TOP/E) simple? As you mentioned it is done via the IO's available on the kolver controller.
As iiwa robot controller uses EtherCAT as a communication bus so I was looking for what could be a best interfacing method to the Kolver controller.
Thanks.
