Home › Troubleshooting
Grady_Turner
Posts: 67Founding Pro, Partner, Beta Tester VIsion 1.1 Program, Wrist Camera URCap 1.3.0 Handy
Trouble Calibrating Camera Demo with UR3 |
/ Most recent by Enric |
12 comments |
Is anyone having an issue getting the camera calibrated?
Every time the calibration process stops before taking the 18 calibration poses. I have tried different backgrounds and different starting positions (making sure to update the "snapshot pose" feature). When I press "calibrate," the robot moves to a few locations taking pictures (differs in number depending on where I start relative to the board) and then for a few seconds the picture area on the left shows the Poses 1-9 grid. After that the camera begins flashing on and off and the "Calibrate" button is available again.
I know in the training something that was discussed was having error messages, or failure notices since those are not explicit.
Any advice, thoughts? I may be missing something very simple.
Other than that, @PierreOlivier_Proulx and @MarcAntoine_Lacasse, do you have any ideas?
@PierreOlivier_Proulx @MarcAntoine_Lacasse any advice would be greatly appreciated.
Regarding adding explicit error messages, it has been integrated. I could probably send you an update tomorrow.
Software Designer
It looks like every time the system calculated the 18 poses, pose 11 "inverse kinematic" request returned false, and so the calibration failed. This was consistent on pose 11 every time.
I am doing this on a UR3, and as I mentioned, I tried several starting locations knowing how the robot might move, but my guess is that pose 11 is either too close to the base or too far away from the base. Any advice?
With the UR3, the squares of the grid must be 8.24 mm. You will find attached the original grid. To achieve the right dimensions, I printed it with a 58.8% scale factor. You should still verify the dimensions after printing.
Software Designer
Software Designer
Software Designer
Software Designer
UR3 with Vision. We use your CalibrationBoard!.
Vicosystems S.L.L.
