jkk912
bcastets said:
There is a check box wait until complete. Therefore you are sure the gripper is open or closed after such a gripper command.
zoom
I have that checked. The position data was needed just to set up an output to give a visual indication on the HMI of "gripper open" or "gripper closed" and not out of a concern that the robot would move before it was in the correct position.
bcastets said:
You could save the gripper status in a variable that you update after each gripper command
This is exactly what I ended up doing.
Thank you for the help and the prompt responses.
