bene
Posts: 6 Recruit
ROS2 and Ignition support for Robotiq 2F-85 gripper??? |
/ Most recent by bene
7 comments |
I am thinking about purchasing a Robotiq 2F-85 gripper. I would like to mount it to a UR5 robot arm from Universal Robots and control it via ROS2. At the moment I am using Galactic Geochelone running on an Ubuntu 20.04 computer and as soon as the next LTS version is available, I will upgrade to that one (Humble Hawksbill). I am not new to robotics nor ROS, but it is the first time I am using an actual industrial robot arm. So maybe I have overseen something. I have the ROS2 package from Universal Robots installed. So maybe the URCap is solving my issue?
I am wondering if there is an official ROS2 package from Robotiq that allows to control the 2F-85 gripper? I have seen the ROS Industrial repository https://github.com/ros-industrial/robotiq but it seems that it is no longer maintained what made me a bit worried. Furthermore, I would prefer native ROS2 support instead of using a ROS1 to ROS2 bridge.
Another question is if I have to connect the gripper to the UR's control box or if I can control it independently using ROS2 just by installing a RS485 to USB converter and plug the USB connector into my computer?
On top of controlling the gripper, I would like to simulate it using Ignition Fortress (successor of Gazebo) and perform motion planning using Moveit2. Are there official instructions from Robotiq on how to do that? If not, what would be the best way to go?
Thanks for your support.
Best regards,
Benedikt
Best regards,
Benedikt
bcastets Vacuum Beta tester Posts: 572 Expert
Your post resume quite well the situation.
We have 2 types of gripper couplings. One to connect the gripper to the controller via RS485/USB converter and another to connect the gripper at the wrist of eSerie. The version directly connected to the controller is probably the most flexible because you can both connect on the UR controller or the ROS PC.
If you develop a ROS2 package place check it here so that other members of the community can contribute.
The gripper can be connected on the UR robot or directly on the ROS PC. Direct connection on ROS PC via RS485éUSB converter is probably the easiest way to go. The current robotiq ROS package is design to work like this.
You can find more information about how to control a gripper connected to a UR robot in this post:
https://dof.robotiq.com/discussion/comment/7296#Comment_7296
As for the simulation in the current ros package I know we have some model but I am not just this will fit for you.
So if I understand you correctly I have to download the URCap file from https://robotiq.com/support/2f85-140-adaptive-robot-gripper (see attached screenshot) and install it on the robot via the teach pendant.
This will install a URCap server that I can send commands to using your Python file from https://dof.robotiq.com/discussion/comment/7296#Comment_7296 . I can wrap the Python file into a ROS2 node in order to control the gripper with ROS2. In this first setup I have to connect the gripper to the control box of the UR with a serial connection as shown in this video
Regarding simulation I will most likely use the model provided from https://github.com/ros-industrial/robotiq and hope that the physics parameters are accurate enough.
