Home› Robotiq Products
Matt_H
Posts: 10 Apprentice
Wrist Camera Data |
/ Most recent by bcastets |
5 comments |
Where is the Data stored for the camera locate?
Specifically when I teach a part (Lets say a ring/Circle) I have to add the Diameter and Height of each part I want to locate.
Rather than teaching potentially hundreds of Cam locates for different sized parts (all are rings/circles). I want to edit the data for the part size prior to running the cam locate.
Unfortunately it is not possible to set a parametric model via a variable. It will share your need to our development team to see if we can implement this in the future.
The program is ridiculously long and when trying to run it it just crashes the Polyscope
I need a better solution than having so many Cam locates.
Any update from the development team?
Indeed 93 camlocate is too much. I open a support ticket so that we try to find a better solution.
Il you have a lot of different size you can create a program for each size and there for decrease the number of camlocate in a program.
