Home› General
I need Hand-E finger tip extensions so the fingers are 5 inches wide (open) |
/ Most recent by bcastets
in General
10 comments |
Hello DoF community!
I'm new, got my UR5e and Hand-E gripper last week. Currently the rubber fingers are 2 inches wide (open) I need the grippers to go as wide as 4.5 - 5 inches. My idea is to ad 1.5 inch extensions to each finger. It wouldn't be able to close completely but thats ok for my purposes. Any thoughts and ideas would be grateful. I was thinking I could get these extensions 3D printed maybe.
Catherine_Bernier Posts: 144 Handy
Hey Matt, yes this can be doable and also Robotiq now has fingertips extenders that can be used on Hand-E. They will offer you from 40mm to 100mm of opening and any 2F fingertips can work on those.
This is a base that you can work with to extend to the size you want and easier to customize. However, keep in mind that the forces applied on the gripper needs to remain inside the limit of the gripper. (More info in the manual)
Here is an image:
Ask your distributor to get them.
Thanks!Catherine Bernier, Jr. Eng.
This part can be ordered with this number: HND-TIP-EXT-KIT
Thank you!
Best,
Alex
https://assets.robotiq.com/website-assets/support_documents/document/Offering_20FingertipsF_FE2020_F_20200313.pdf
The following items are necessary to replicate the same setup:
- HND-TIP-EXT-KIT Finger extender kit
- AGC-TIP-MLD-KIT-85 Flat rubber overmolded fingertip kit
The finger our your picture is the old version of the overmolded fingertip. It has been discontinued. This is why you cannot find it in our catalogue.We may have some in stock if you need them.
The reference is: AGC-TIP-204-085 Flat Silicone Fingertip for 2F-85-V4
Aluminum fingers are also running well. I wanted to get a decent collection of fingers as parts we run change all the time and I am pretty new to this. I'll try to see if we can still get any stock leftovers just in case.
Best,
Alex
You probably have Hande silicone fingers however they do not fit on the extender.
Only 2F fingers can be mounted on the extender.
Not sure if it is a good recommendation but you could eventually change the surface aspect of the overmolded finger to avoid sticking effect.
