Home› Robotiq Products
pfg
Posts: 3 Apprentice
Thanks
Pierre
Wrist Camera, calibrating process |
/ Most recent by bcastets |
5 comments |
When creating a Snapshot Position, is it possible to:
1. create a base Full Calibration at an "easy" location.
2. create a "real" one (related to the first one) with New Work Plane & Position at the working location.
Something like this?
I tried but without success (at first look the robot moves in opposite direction...). I can't do Full Calibration at the working location as I get messages about not enough reachable poses and that the board is too far from the robot.
Also, I don't understand why the Full Calibration Snapshot is located at the robot's base and not at the calibration board location?
Thanks
Pierre
First create a full calibration and then define the new work plane and snapshot position.
If the robot goes in a strange direction when it tries to pick the object after detection, it may be because the feature point use by the camLocate is not selected as Move feature.
I recommend to check the following eLearning video to learn more about how to define a new work plane:
https://elearning.robotiq.com/course/view.php?id=5§ion=10
If you still face problem, you can send more information (program, video) to [email protected] for investigation.
But I tried a few more times, starting form scratch each time and now I have something that works. Not sure why though.
Random? I don't think so. But I noticed that if the program has not been saved, these references are not updated in the graphic views (even though they are used correctly in the code).
The location of the feature point is not important.
This point is used as a reference by the camera. The position of this reference point is updated after each object detection during program execution. The point does not need to be at a specific location like being on work plane.
You don t need to worry about the location of this point. This is use in the background by the camera.
Also do not edit the position of this point in installation menu. This may affect the camera relative moves you have in your program.
I also recommend to check our elearning contents to learn more about it.
