Home› Integration
bcastets
Vacuum Beta tester Posts: 611 Expert
Integration of Robotiq gripper on Fanuc CRX |
1.2K views
/ Most recent by bcastets
in Integration
8 comments |
Have you ever integrated Robotiq gripper on Fanuc CRX ?
I would like to share with you some work done by Fanuc US team.
They made an integration using the Karel routine attached to this post.
Here below are the comments of the developer who made this integration:
The connection is made using modbus RTU at the wrist.
The bolt pattern of Fanuc CRX is same as UR:
Robotiq_cmd.pc takes 3 arguments, arg1 is position, arg2 is speed, arg3 is force. Each should be an integer values 0-255 (0 is open/minimum, 255 is closed/max). Currently this is open loop so there is nothing that listens for a status from the gripper after the command was sent.
Verify these in the System Variables:
* You need to update $TLIF to get voltage to the EOAT. Set $TLIF.$POWER_VOLT[1] = 2 for 24V supply. Power cycle to apply it.
* Set $TLIF.$BAUD_RATE to 3
* Set $TLIF.$DO_MODE[1] and [2] = 0
* Power cycle.
* Power cycle.
50 mm PCD with 4 x M6 threads
Our eSerie serial coupling (GRP-ES-CPL-062) can be used to make the connection at the wrist. Connector and pinout match Fanuc CRX.
Please share your integration experience on this post !
Here below is eSerie serial coupling pinout:
Here below is CRX EE interface pinout:
Connector datasheet:
https://ca-en.alliedelec.com/m/d/741df2a90ab8d03ba5c3068f60cf8f66.pdf
The drawing of the wrist connector in Fanuc manual is a bit confusing with the pin 8 indicated on connector index instead of the center but it is the same connector.
This would work only if CRX and UR CB have
- Same IO pinout
- Same type of IO (NPN/PNP)
I could not found information about the type of IO at the wrist of fanuc CRX.https://wilderdx.com/
- The digital IO of Fanuc CRX can both use NPN or PNP so there is not problem of IO type compatibility
- Documentation shows that pinout of UR IO does not match Fanuc CRX IO pin out however from what I heard from Fanuc UR CB and Fanuc CRX should have same pinout. Fanuc may have a mirrored representation of the pinout.
Here below is UR pin out :Here below is fanuc pin out :
If as Fanuc said the pinout of UR and CRX match, it should be possible to use Robotiq UR IO coupling (IO-CPL-UR-CB-KIT) to integrate Robotiq grippers.
You should be able to control 1 gripper with the IO coupling. We did not get any feedback about users who use the IO coupling on CRX but on the paper it should work.
Unfortunately it is not possible to control 2 grippers with IO coupling. This coupling is designed to be used by only 1 gripper.
Serial communication is probably the best to control a dual gripper on CRX but it require some Karel coding.
If you manage to use the IO coupling on CRX, please share your experience ! I would be curious to know if the integration works well like this.
