Home› Troubleshooting
c1374153548
Posts: 10 Apprentice
ft sensor problem in ur3e |
/ Most recent by c1374153548 |
12 comments |
Hello, I'm a graduate student and I am going to use ur3e to do grinding and polishing through ROS.
However, I find the force torque sensor is becoming bigger and bigger when I use ROS to control it.
The agent said that using force mode can get the correct data.
Here is my problem.
Why does sensor data change with robot mode?
I try to add an external control in force mode, but the robot starts moving(I have not found the cause), which means that I can't use ROS under force mode.
If there is a method that I can successfully read the ft sensor data from ur3e through ROS?
Looking for your reply, thank you very much.
Force mode is a preprogrammed force control algorithm. It will not fit if you want to make your own force control algorithm.
For your information we have a ROS package for the FT300:
http://wiki.ros.org/robotiq_ft_sensor?distro=kinetic
So I have to use external FT sensor to realize force control with ROS?
I don't think you need force control mode.
UR have some ROS package. Maybe you can find something here:
https://github.com/UniversalRobots/Universal_Robots_ROS_Driver
My ultimate goal is to read correct force torque data in ROS.
https://github.com/UniversalRobots/Universal_Robots_ROS_Driver/issues/269
Do you mean that ROS can not use ur3e integrated force sensor?
So should I use ft300 with ROS?
您是说ROS无法使用ur3e集成式力传感器吗?
那么我应该将ft300与ROS一起使用吗?
