Hao0420
Posts: 3 Apprentice
Problem reading FT300 sensor data from Modbus EasyModbus.dll library in Windows form C# |
/ Most recent by Hao0420
3 comments |
I'm right now trying to read sensor data through USB-RS485 converter and utilizing the EasyModbus.dll in C#.
However, I've kept receiving CRC checked failed at the ReadHoldingRegister
part. The connection and reading part is shown below.
I've already done lots of research but still can't solve the issue. Can anyone help me with this?
The CRC checked failed will occur at
int[] Read = modbusClient.ReadHoldingRegisters(179, 6);
The FT300 Modbus Setting is also shown below:
Image is stolen from this manual, page 34
void getavailableports() // get available COM { comboBox1.Items.Clear(); string[] ports = SerialPort.GetPortNames(); comboBox1.Items.AddRange(ports); } private void comboBox1_MouseClick(object sender, MouseEventArgs e) //let user choose COM { getavailableports(); } private void Start_Click(object sender, EventArgs e) // Start button being pressed { try { Invoke(new EventHandler(ChangeColor)); //FT300Port.PortName = comboBox1.Text; //.BaudRate = Convert.ToInt32(BaudRate.Text); //FT300Port.Open(); modbusClient.UnitIdentifier = 9; // default slaveID = 1 modbusClient.Baudrate = Convert.ToInt32(BaudRate.Text); // default baudrate = 9600 modbusClient.Parity = System.IO.Ports.Parity.None; modbusClient.StopBits = System.IO.Ports.StopBits.One; modbusClient.ConnectionTimeout = 500; modbusClient.Connect(); lb_status.Text = "Connected"; timer_Modbus.Enabled = true; } catch(Exception ex) { lb_status.Text = ex.ToString(); throw; } } private void ChangeColor(object sender, EventArgs e) { Start.Text = "Streaming"; Start.BackColor = Color.Red; } private void Disconnect_Click(object sender, EventArgs e) { modbusClient.Disconnect(); Start.Text = "Start"; Start.BackColor = Color.DarkGray; lb_status.Text = "Disconnected"; timer_Modbus.Enabled = false; } private void timer_Modbus_Tick(object sender, EventArgs e) { timer_Modbus.Enabled = false; //modbusClient.WriteMultipleCoils(179, new bool[] { true, true, true, true, true, true}); //Write Coils starting with Address 180 //bool[] readCoils = modbusClient.ReadCoils(179, 6); **int[] Read = modbusClient.ReadHoldingRegisters(179, 6);** /*textBox1.Text = Convert.ToString(Read[0]); textBox2.Text = Convert.ToString(Read[1]); textBox3.Text = Convert.ToString(Read[2]); textBox4.Text = Convert.ToString(Read[3]); textBox5.Text = Convert.ToString(Read[4]); textBox6.Text = Convert.ToString(Read[5]);*/ timer_Modbus.Enabled = true; <span>}</span>
Hao0420 Posts: 3 Apprentice
For anyone facing the same problem: https://github.com/HanHao0420/FT300-sensor-Modbus-RTU-
I've already solved the problem and the original codes are put on Github.
Feel free to ask me any question!
syed Posts: 4 Apprentice
Did you figure out the problem ?0 · TwitterFacebook -
0 · TwitterFacebook
