haneulineshaneulines Posts: 22 Apprentice
Is there a way to move the robot freely without pressing the freedrive button.
    We wire an on off switch to an input and set the function as Freedrive.
    You could have a PLC/PC send a script to the robot that uses the freedrive command. Something has to command the robot to enter that mode.
  • MarcAntoine_GauthierMarcAntoine_Gauthier Vacuum Beta tester Posts: 44 Handy
    Hello @haneulines
    If you have the Robotiq Force Copilot, you could use the Active Drive feature to move the robot without holding a button.
    See here a video of that feature on our eLearning platform.
    Let me know if you have any questions.
    Regards.
  • PassakornPassakorn Unconfirmed Posts: 2 Recruit
    Hello @matthewd92 @MarcAntoine_Gauthier
    If I want to use a freedrive in robot program.
    Is there any function or script to use it?
    Thank you
  • haneulineshaneulines Posts: 22 Apprentice
    Unfortunately we do not have the robotiq force Copilot..
    I'm also really interested by the script that uses the freedrive command.. Where could I find it ?
    Is there any post on the forum about this subject ?
    Thank you !
    Yes, the script code is freedrive_mode() and then when you are ready to turn it off you issue the end_freedrive_mode()
    So for instance we have have a home “box” that the TCP must be in before we can start a program. If the TCP location is not inside the box when we start we enter free drive until it is and then turn it off.
    On another robot we have a button on the end of arm and when certain conditions are met we allow the user to freedrive the arm while the program is still playing as long as they press a button on the end of arm tool so we have a while loop so long as they hold the button that just syncs. As soon as they release we exit free drive.
