Home› General
UR10 CB3 series - Meaning and source of outputs received through RTDE |
/ Most recent by matthewd92
in General
3 comments |
Hello Everyone,
I am working on the robot (Universal Robots - UR10 CB3 series) data received through RTDE for quite a few months now. My objective is to understand the source of the values for the outputs received through RTDE as well as the meaning and relationship between the outputs.
For example, the values under "joint_temperatures_0" are received from the temperature sensor present in the "joint_0" of the robot.
I already have found out, that the output "joint_control_ouput_0" is the target current for the motor in "joint_0". This is true because the values under "actual_current_0" and "joint_control_output_0" are same. Whereas there is another output called "target_current_0", for which there is not much information provided and therefore I have the following questions:
1. What is the meaning for "target_current_0"?
2. What is the theoretical relationship between "target_current_0", "actual_current_0" and "target_control_output_0" (obviously w.r.t the joint motor)?
Thank you in advance
thank you for your reply.
I have noticed that target_current and actual_current are not same, instead actual_current and joint_control_output are same.
Is there any documentation available how the motion model is designed for UR robots?
To my understanding so far, based on the target joint positions, target joint velocities and target acceleration, the target torques are estimated using inverse dynamics and further the joint controller estimates the actual joint voltages required to move to the joints to desired target positions.
I am still trying to understand the following:
2. There is an accelerometer in the tool flange, I would assume these values are from there
3. This should be the temperature of the tool flange itself as opposed to wrist 3
I do not know of anything that is published regarding the motion model. I do know you can get all the motion parameters, DH parameters, etc for the arm. I believe there is a file on the controller that contains the actual specific parameters for your arm, check the calibration.config file under .urcontrol folder.
