tor_odigotor_odigo Posts: 9 Apprentice
edited May 2020 in Programming
Simple question about making functions in script codes in Polyscope on UR:
when making function like this:
def Funk()
set_digital_out(0,True)
end
and then make another script code with the line:
Funk()
I get an error message on the set_digital_out(0,True). What am I doing wrong?
Thanks in advance,
Tor
  • bcastetsbcastets Vacuum Beta tester Posts: 293 Handy
    The ":" is missing after Funk().
    Here below is an extra of UR script manual which you can download from UR website:
    set_digital_out(0,True) looks ok.
    Here below is the description of set_digital_out available in UR script manual.
  • tor_odigotor_odigo Posts: 9 Apprentice
    That was it! Should have looked more carefully... Thank you.
