bcastets
Vacuum Beta tester Posts: 601 Expert
Wrist camera: Control picking order |
/ Most recent by tboizumault
4 comments |
By default the wrist camera process detected objects from high to low detection score. However in some application like "tray picking" you may prefer to control picking order.
This post present a program which process detected objects line by line.
Here is the methodology:
- Detect tray position with the camera and save it in a variable. From this position, it is possible to locate all tray placements.
- Detect with the camera the position of all objects available in the tray and save it in a list.
- Use the distance between object position and tray placements to process objects in the desired order.
The 2 camlocates used in this program use parametric mode.
The first camlocates search for a scare of the size of the tray.
The second camlocate search for a circle of the size of the object in tray placement.
I hope it will help.
I attach some additional information that might help understand parameters and logic.
