Kasem
Posts: 8 Apprentice
Freedrive mode with Servoj in same URscript problem |
/ Most recent by jelms
2 comments |
Hello
I'm working on controlling UR3e SW V5.6 over Profinet , i want to execute trajectories by sending the joints positions and control free drive too based on if conditions dependent on bit registers , as shown in the URscript below , but i have a problem that the robot vibrates if both variables are false and if i touched the robot , the trajectory execution works and free drive works too , but i think the problem is in the else part , i want to end free drive mode and go to default positions ,this is where the robot vibrates
def joints_move_register_v3():
Exceute_trajectory=read_input_boolean_register(3)
Exceute_Teach_Mode=read_input_boolean_register(4)
if (Exceute_trajectory == True and Exceute_Teach_Mode == False ):
q0=read_input_float_register(0)
q1=read_input_float_register(1)
q2=read_input_float_register(2)
q3=read_input_float_register(3)
q4=read_input_float_register(4)
q5=read_input_float_register(5)
q=[0.0,-1.57,q2,-1.57,q4,q5]
servoj(q,0,0,0.008,0.1,300)
elif(Exceute_Teach_Mode == True and Exceute_trajectory == False ):
freedrive mode()
else:
end_freedrive_mode()
q=[0.0,-1.57,0.0,-1.57,0.0,0.0]
end
end
if someone who have good URscript programming skills please help me to make it work
Or if you want to use joint norm
