JAYJAY Posts: 1 Recruit
I didn't changed any hardware settings, and it worked a month ago.
There doesn't seem any problem in hardware setting. But i could find the green led blinking irregularly as you can see in the video.
As you can see in the video, i also fixxed the IP but i can't figure out what's the problem.
I'm not familiar with computer settings, so the detailed explanation with descriptions would be very nice.
I re-installed Robotiq user interface to the latest version, and also wiggled the COM port, but it didn't work.
I guess there exist some software problem with communication, as the instruction manual says that if green LED is blinking, Network is detected, but no
communication is established.
  • bcastetsbcastets Vacuum Beta tester Posts: 610 Expert
    The default gripper IP is 192.168.1.11. However your PC have same IP. You need to set a different IP for you PC (ex:192.168.1.10).
    Try changing the IP of your PC.
    If you are still facing problem, please contact [email protected]
