sennrobo
Posts: 2 Recruit
Examples of Gripper Calls using RoboDK Python API |
/ Most recent by bcastets
2 comments |
Greetings,
Getting my feet wet with the RoboDK Python API. The software has been great for movement macros and flow control, but I am having trouble programming calls for our 2-finger gripper on our UR5 using the Python API.
It appears that RoboDK recently released a Universal_Robots_RobotiQ post processor, but I have not seen any documentation or example code which takes advantage of the post processor.
Has anyone successfully programmed the Robotiq gripper using the Python API? If so, what was your trick? Any examples would be very appreciated.
Did you got some response to this question? Or did you found the solution?
Gratefully,
Daniel Vieira
Once you have the solution, come back and share it with us!
