Home› Troubleshooting
Brittaney541
Posts: 34 Apprentice
Robot IP Address?? |
/ Most recent by matthewd92 |
3 comments |
matthewd92 Founding Pro, Tactile Sensor Beta Testers Posts: 1,184 Handy
You need to assign up addresses to both the robot and the cylinder. Generally you are using a router and you will have to follow the routers up address structure. If you connect them directly together you could set the up address of the robot to 192.168.1.2 and the cylinder to 192.168.1.3 and then on the modbus client screen you will need to connect to modbus client at 192.168.1.3.
You will probably need a computer to set the IP address on the cylinder or it may be done with dip switches. Your distributor or dealer should be able to help you get this system connected.
The robot can use either DHCP or static IP addresses.
