Brittaney541Brittaney541 Posts: 34 Apprentice
How can I find my Robots IP Address? Does the UR even have its own IP Address? I went to About.. and it said 000.000.00.00.
    edited July 2019
    Have you set up the IP address, by default it’s turned off. Depending on CB3 or e-series the path to the network setting is different. On CB3 on the main screen go to Setup robot and then network settings. On the e-series clock on the “hamburger” on the top right and then go to settings. Network is under system settings.
    The robot can use either DHCP or static IP addresses.
    It is an E-series and no I haven't set up the IP address. I don't really know much about IP addresses. Not sure if there is a set one or if you make one up and what the stipulations are to set up an IP address. I'm trying to hook up a pneumatic cylinder to my Modbus. And the information on Universal robot support page is super confusing to me.
