How to achieve accuracy in UR3e with moveL or J for dynamic continues(0.02sec) displacement |
/ Most recent by matthewd92
1 comment |
We have UR3e robot with SW ver 5.4
Our requirement is UR has to move(move-L/J) to the dynamic displacement given as a pose value ranging from micron to mm in XYZ and 0.01 deg to 10 deg in RXRYRZ with time t = 0.02 speed.
We tried using move-L/J (ex:movel(p[*,*,*,*,*,*],t=0.2)) command through socket programming with the delay of 0.01sec for each move command and end up with the poor response in the final moved distance, robot RTDE values are also matching after ~500 msec for each move command finally the total expected move is always coming with error of ranging from 50 micron to 300 micron sometime this goes to mm also.
Is there any way to tune the robot with UR script to get the continuous(0.02 interval) move with a maximum speed ?
The better option is to use a servoj command and send the command every 0.002 and command the robot where to move each time slice, this will give you very smooth motion and also allow you to control exactly where the robot is going and how fast it gets there. You have to plan the distance to move based on speed and acceleration so there is more that you have to calculate but this gives you the best control over the robot motion.
