Andre
Posts: 17 Apprentice
Is it possible to call a function on the UR with TCP/IP? |
/ Most recent by Andre
4 comments |
Good time of the day to everyone,
I am using a UR10 CB-series with Polyscope 3.9 and LabVIEW to control it.
I would like to know if it possible to call a function defined inside the robot program by using TCP/IP. I know that, using the port 30001, I can send a command string such as:
def fnc_move():
movel(p[x,y,z,rx,ry,rz],a,v)
end
and the robot will move with a certain speed and acceleration to the waypoint.
My question is about calling a function defined as a .script file on the UR such as: "fnc movel(wp,a,v)", by sending a command string like "fnc movel(p[0.1,0.2,0.3,0,3.141,0],0.5,0.5)" to call the function stored inside the UR with specific parameters by using TCP/IP.
Do you know if it is possible to do something like this or similar?
Thank you very much for your help and I wish you a nice day
Best regards
Andrea
def fnc_move():
end
Best regards
Andrea
If a program was running and the function didn’t cause motion then I believe you could send it as a secondary program. Anything sent as a primary program stops the execution of the current program to run the new program.
Example:
.script function on the UR program:
def fnc_move(wp,a,v):
movel(wp,a,v)
end
function called in the Robot Program (classic approach):
fnc_move(p[0.1,0.2,0.3,0,3.141,0],0.5,0.5)
I would like to write on the Robot Program, when calling the function, just:
fnc_move(wp,a,v,)
and to call the function with full parameters or to send the input arguments from LabVIEW with TCP/IP like:
or maybe even just to update the input arguments of the fnc_move somewhere, maybe in .script file, before calling the function in the Robot Program.
Do you know if such a thing is possible and how to do that?
UR also provides a tcp/ip method for requesting a variable or you can pass a string and have the server respond with the correct variable. Then there’s no need to use port 30001, the program is making the request and labview is just responding with the correct response.
Best regards
Andrea
