Dear Mr @matthewd92,
Case-1:
From third-party software am sending co-ordinates to ur3e, in that when am converting Rz value from degree to radian, am getting an error value.
 For both +180 or -180, the conversion results are -3.14.
This happens only for 180 degrees.
Case-2:
I tried to move rz manually, but the directions are confusing.
    How are you converting the Rez, on the UR or third party software?
  • PrasannaPrasanna Posts: 56 Apprentice
    Am just sending the values like 180 or -180
    in the UR program, i did convert using d2r
    But for both Positive and Negative The value d2r value is -3.14.
    What version of Polyscope are you using?  I just ran a test on Polyscope 3.8 and the signs are correct +180 -> +3.14, -180 -> -3.14
