laddladd Posts: 4 Apprentice
I have looked into this checked fuses on board all check ok unless getting feed back thru printed circuit  24 and 48 volt less do come on for a brief second then go out then alarm  as I have a few controllers can i swap the safety bord out of one of them ? All ur10 cb3
  • laddladd Posts: 4 Apprentice
    Yes 48v is ok. After  checking connections again found terminal loose on jumper
    On power
    Thanks for the reply
