I want to communicate in Modbus RTU with the Robotiq FT300, but I can't.
I am using a RS232 to RS485 adapter as I know your sensor communicates in RS485.
Any ideas why it doesn't work?
Thanks
    Well thanks!
    This was the problem... My converter wasn't setup properly.
    Thanks for your support!
  • jainaayush2006jainaayush2006 Posts: 1 Recruit
    Hey there,
    I'm also trying to do the same thing, trying to communicate with FT300 with Arduino using RS485 to RS232 adapter and then using RS232 to TTL converter. I not good at coding, so please can someone help me with the code to read the values on Arduino.
  • bcastetsbcastets Posts: 49Vacuum Beta tester Handy
    Hello Aayush Jain,
    The following arduino library looks like a reference for Modbus communication:
    https://github.com/4-20ma/ModbusMaster
    I found some interesting video about how to communicate in Modbus RTU with ardiuno. I recommand you check that:
    https://www.youtube.com/watch?v=HPZrGuBtk_c
    https://www.youtube.com/watch?v=tBw15SfmuwI
    I did not tested but based on those videos, I would make a program like the following to display force and torque on Ardiuno console on PC side:
    #include <ModbusMaster.h>
    #define MAX485_DE 3
    #define MAX485_RE_NEG 2
    ModbusMaster node;
    void preTransmission()
    digitalWrite(MAX485_RE_NEG,1);
    digitalWrite(MAX485_DE,1);
    void postTransmission()
    digitalWrite(MAX485_RE_NEG,0);
    digitalWrite(MAX485_DE,0);
    void setup()
    pinMode(MAX485_RE_NEG, OUTPUT);
    pinMode(MAX485_DE,OUTPUT);
    //Init in receive mode
    //Modbus communication runs at 19200 baud (according to FT300 manual 4.4.1 ModbusRTU)
    Serial.begin(19200);
    //Modbus slave ID 9 (according to FT300 manual 4.4.1 ModbusRTU)
    node.begin(9,Serial);
    //Callbacks allow us to configure the RS485 transceiver correctly
    node.preTransmission(preTransmission);
    node.postTransmission(postTransmission);
    void loop()
    uint8_t resutlMain;
    //Read registers where is written force and torque value (according to FT300 manual 4.4.1 ModbusRTU)
    //Register : Description
    //180: Fx
    //181: Fy
    //182: Fz
    //183: Mx
    //184: My
    //185: Mz
    //Read 6 registers starting from address 180
    resultMain=node.readInputRegisters(180,6);
    if (resultMain == node.ku8MBSuccess)
    Serial.println("----------------");
    Serial.println("Fx: ");
    Serial.println(node.getResponseBuffe(0x00 / 100.0f);
    Serial.println("Fy: ");
    Serial.println(node.getResponseBuffe(0x01 / 100.0f);
    Serial.println("Fz: ");
    Serial.println(node.getResponseBuffe(0x02 / 100.0f);
    Serial.println("Mx: ");
    Serial.println(node.getResponseBuffe(0x03 / 100.0f);
    Serial.println("My: ");
    Serial.println(node.getResponseBuffe(0x04 / 100.0f);
    Serial.println("Mz: ");
    Serial.println(node.getResponseBuffe(0x05 / 100.0f);
