AmeyakarnikAmeyakarnik Posts: 12 Apprentice
Can anyone explain me these script codes
(get_applied tcp wrench(2)>25).
I saw this code in (New FT 300 feature).
I also want to program in similar way for my application.
Thanks in Advance
FT.png 99.5K
  • AmeyakarnikAmeyakarnik Posts: 12 Apprentice
    thanks that helped me .
    when I enter the code  " get _applied_tcp_wrench(4)>25"  and then as I run the Program there is an error telling it is not defined. What is the reason for that?
    anoher question how is this code different from " get_tcp_force() " ?
    Thanks in Advance
    What version of poly scope are you running?  That is a rather new feature.
    Its version is 3.7.2
    I also want to know the difference between get_applied_tcp_force()  and get_applied_tcp_wrench() . As i couldnt  find those in UR Script Progamming language
    Hallo,
    I tried the (reorientation demo with FT300). When the robot moves in the z-axis waiting for the 25 N to be detected and as soon as it detects it does not orient perpendicular. What should i do so that it can orient perpendicular to the surface.
    Hello @Ameyakarnik
    What are you trying to align exactly?
    You'll need a contact large enough to be able to align it on a surface.
    If you try for example to align a part with just a few square inches of contact, it won't be possible.
    The larger the object, the more moment will be applied so it will be easier to align it flat on the surface.
    David Gariépy
    I have drawn roughly the front view and side view of thr instrument to be alligned. Its moving down in the slant position (Not perpendicular to the surface). When it detects 25 N on one tooth of clamp. Instead of alligning perpendicular to the surface it retreats back.
    Could you please post a picture of your program and the setting in the force control node?
    David Gariépy
    Here are the photos.
    To avoid bounce back, you can try to untick the adaptive stiffness and set your own.
    The higher the stiffness, the slower the compensation. I would start with 80% stiffness for the z axis.
    But it is very likely that the point of contact aren't large enough.
    What is the size of your tool? or could you please post a picture of your setup?
    Best regards
    David Gariépy
    Are you trying to rotate the tool while pressing down?  If so, have you tried making the appropriate rotation axis compliant as well?  Otherwise it won’t rotate
