vicvic Posts: 8 Apprentice
hello.
i have 3 hand-e grippers, 2 with controller Ethernet ip and 1 with rs485-usb converter to ur5 robot direct conection.
I have tried to operate them with virtual box and urcap but isnt work.
I have tried to operate them with robotiq user interface but isnt work.
    @vic i opened a support ticket and we will contact you. When you tried the setup with the Robotiq User Interface, how were you configured? Did you have power to the gripper? If yes, LED should be red. Then when you connect the RS-485 to USB converter to your computer the Robotiq User Interface should display the COM port, if it's not there contact us. If it is there, please try to reset the Gripper (see manual).
    Best,
  • vicvic Posts: 8 Apprentice
    thanks Etienne_Samson.
    the gripper led dont turn on.
    when i used the user interface with gripper + controller Ethernet ip is detected but it is not operated, i attach a picture.
    when i used the user interface with gripper + converter rs485 to usb, is it not detected.
    when i used virtualbox + ursim + urcap + controller ethernet ip device is not detected, i attach picture.
    when i used virtualbox + ursim + urcap + converter rs485 to usb, device is not detected.
  • David_LevasseurDavid_Levasseur Posts: 175Beta Tester Beetle Handy
    @vic, thanks for the pictures. Connect the green wire to pin 7. As for using the gripper in URSim, follow the attached procedure.
    hello David_Levasseur.
    i connected the Green wire to pin 7 and followed the instructions like attach file, the gripper dont fuction.
    now i checked the wires grippers and one pin (vcc) is wrong.
    i proved with other wire and the gripper functioned in robotiq user interface with rs485-usb, but dont work in:
    robotiq user interface + controller Ethernet ip + wire Ethernet
    robotiq user interface + controller Ethernet ip + wire usb
    virtual machine + ursim + urcap + rs485-usb
    virtual machine + ursim + urcap + controller Ethernet ip + wire Ethernet
    virtual machine + ursim + urcap + controller Ethernet ip + wire usb
