Home › Programming
Ameyakarnik
Posts: 12 Apprentice
I wanted to know if its possible to insert a Pin like structure with help of FT-300 sensor? |
/ Most recent by David_Gariepy
6 comments |
David_Gariepy Posts: 176 Handy
@Ameyakarnik
Simply download and install the latest URCap from our support website and you'll have access to the insertion node from the urcap menu of polyscope.
Note that you'll need version 3.6 or higher of polyscopeDavid Gariépy
Integration Coach -
Hi @Ameyakarnik
Polyscope update are downloadable from ur support website as .urup extension. Here is a direct download link. There is no need to change its extension.
Regarding the URCap, for the ft 300, it can be downloaded from our support website, here is a direct download link.
This one will be downloaded as a compressed .zip file. you'll have to extract it using software such as winzip or winrar
David Gariépy
The insertion node simplify the process
https://www.youtube.com/watch?v=sC09RAR0TKc
Can also be used on a more fragile part such as electronics, see here
What is the size of the pin?
The size of the pin is 5 cm long and 0.4 mm thick.
Even then it is not showing in the controller. Am i missing somthing?
0.4mm is pretty small, you'll have to test it to be sure it does not damage the pin.
