AmeyakarnikAmeyakarnik Posts: 12 Apprentice
Thanks in advance
    Hello @Ameyakarnik,
    The insertion node simplify the process
    https://www.youtube.com/watch?v=sC09RAR0TKc
    Can also be used on a more fragile part such as electronics, see here
    What is the size of the pin?
    David Gariépy
  • AmeyakarnikAmeyakarnik Posts: 12 Apprentice
    thanks for the reply. It helped me. I am new to Poly Scope. Can you please guide me how can i get the option of 'Insertion' on my controller.
    The size of the pin is 5 cm long and 0.4 mm thick.
    I downloaded the latest polyscope software. The file extension was (.urcap). Then according to one of the post I changed it to (.urup).
     Even then it is not showing in the controller. Am i missing somthing?
    @Ameyakarnik
    0.4mm is pretty small, you'll have to test it to be sure it does not damage the pin.
    David Gariépy
