Catherine_BernierCatherine_Bernier Posts: 144 Crew
edited April 2016 in Integration
This how-to is intended for the Robotiq 3-Finger 3.X.X, Kuka IIWA media flange and Kuka Sunrise Cabinet
What you need :
  • Robotiq 3-Finger gripper
  • Coupling for the gripper AGS-APL-157
  • Robotiq IIWA cable kit (electrical or pneumatic media flange) AGS-IIWA-CABLE-KIT-A/B
How to do it :
Mechanical Assembly
  • Install the coupling of the gripper on the Kuka IIWA wrist.
  • Install the gripper on the coupling.
Electrical and Communication installation
Kuka’s communication protocol is EtherCAT. So the built-in controller of the 3-Finger gripper converts the signal from RS485 to EtherCAT.
  • Connect the M8(electrical)/M12(pneumatic) cable for the power to the gripper and to the flange. (X36)
  • Connect the M8 communication cable to the gripper and to the flange.
  • Configure the inputs/outputs in WorkVisual
  • And you are good to go in Sunrise OS.
Enjoy the wire free Robotiq 3-Finger gripper!
Catherine Bernier, Jr. Eng.
  • SamNewSamNew Posts: 6 Apprentice
    Hello, we have purchase a 3 finger gripper (ethercat) for our kuka iiwa, is it possible to control the gripper using ROS after I configure it using Workvisual and Sunrise OS?
    @jproberge, do you think you could assist @SamNew please?
  • jprobergejproberge Posts: 41Tactile Sensor Beta Testers Crew
    Hello @SamNew !
    You indeed can control our 3-Finger Adaptive Robot Gripper with ROS using the Ethercat protocol. However, just to be sure I properly understood your question, will there be two different nodes ( 1-ROS and 2-Workvisual) on the same Ethercat network trying to change the gripper's parameters?
    Best regards,
    Jean-Philippe Roberge,
