FranRugg
Posts: 2 Recruit
Info request & support regarding FT300 |
/ Most recent by Annick_Mottard
1 comment |
hello everyone, i'm new so sorry in advance for any mistakes, i tried to start a discussion already but it seems i lost the link to it
i wanted to ask a pair of questions
- i recall the FT300 had a serious bug which prevents profinet/ethernet connection, for the URcap 1.3, so i had to downgrade to 1.0, i wanted to know it this is solved in 1.6.x
-another problem is the plane movement during active drive, the Z axis was not fixed, i mean that yes the robot tries to stay on plane, but it takes a very minimal pressure in the Z axis to make it deviate from the plane, this for both URCap 1.0 and 1.3, so as well i wanted to know if it's solved in the 1.6 or still too much compliant in the Z.
-Due to those 2 problems, i wrote a custom software which records a path keeping the Z blocked, using only the high sensitivity of the FT300, however i have another problem, using too many installation variables (300 paths) makes the controller take too much time to intialize, so the famous popup error regarding a wait or sync appears, i tried to edit the program at script level inserting some sleep instructions, but as soon as i press play it recompiles and erases my sleeps.
Is there any workaround to use retentive large variables on the robot?
thanks in advance
thanks in advance
Here are my answers to your questions:
There is indeed a compatibility issue with the FT 300 URCap and Polyscope when trying to run a Profinet/Ethernet connection. This is not solved in 1.6. We are aware of this and are working towards making it work in a future version. We unfortunately do not have a time frame to announce for this situation.
