Home› Troubleshooting
iremnurtokac
Posts: 5 Apprentice
Wrist Camera Installation (UCC-1.6.3) Problem |
/ Most recent by iremnurtokac |
3 comments |
I followed the instructions to install the latest software for Wrist Camera. I had no previous software on my UR5 which runs on the PolyScope 3.7.
After the installation, I go to Camera tab and on the Dashboard tab, there is an error saying "Vision System down". How can I fix this installation problem?
I am sharing a photo at the attachment. I've mounted wrist camera and gripper together, the gripper works fine. Thanks!
David_Levasseur Beta Tester Beetle Posts: 182 Handy
Hi @iremnurtokac, This could be a problem caused by how the files were copied to the USB stick. When you download the vision URCap, it comes compressed with a folder. Make sure that the folder called "vision_system" has been extracted directly at the root of the USB stick that has to stay connected to the USB hub. It could also help to format your USB stick prior to extracting the folder. I opened a support ticket to help you if you need further assistance.
thanks for the answer. I unzipped the URCap file directly on the USB (which is provided along with the wrist camera) and plugged into USB hub which is provided too.
The flash drive and USB dongle are recognized, however not installing the features. I see the same issue as the photo above.
I've checked the file vision_system, it is unzipped correctly and the name is correct as well.
