giannis_letgiannis_let Posts: 9 Apprentice
Is there an option inside the polyscope to export the cycle time of the simulated robot? I run a script and the simulated movement is perfect, but where is the cycle time estimation data?
  • Hi @giannis_let,
    I suggest you simply use a thread with a counter that will be running as a timer:
    Main Program
    timer = 0
    cycle_time = timer
    Thread
    timer = timer + 0.008
    sync()
    Note that if you're running on an e-Series you should increment by 0.002s.
    Nicholas Francoeur
    e:   [email protected]
    w:  vanguard-robotics.com
  • matthewd92matthewd92 Founding Pro, Tactile Sensor Beta Testers Posts: 1,020 Handy
    UR does not have cycle time estimates, the best way is to add a thread in the background.  You can then control when to turn on the timer and where in the program you want to capture sub-times, total time, etc.
